Old 09-30-2010, 04:16 PM
Silverback51's Avatar
Silverback51 Silverback51 is offline
Yes, you can notice a difference between the frame mounts supplied in the kit, with the ones I made up. There is absolutely no give in any of the joints any longer.
The kit is a breeze to install. The only thing I missed was that the front a-frame mounts could be installed either on top of, or below the a-frame. Originally installed them below. When I swapped out the frame mounts, I also moved the front a-frame mount to the top location. Just makes it look cleaner, and the sway bar does not hang down as far.
John Hall
