Thread: Major Ding!!
Old 10-01-2010, 05:45 PM
wanab5150's Avatar
wanab5150 wanab5150 is offline
Cobra Make, Engine: Superformance #2769 Roush 427R Dart Block
If you have a photo it would help.
Depending on the depth you would be surprised how good it can look. I've filled numerous goobers on cars since I started painting in 1969. But, it has become so much easier with base coat/clear coat PPG or Dupont etc.
It gets easier the simpler the paint job especially if it's a solid color with no metallic. You will basically fill, color (just enough paint to color the spot), then fill in with REAL Urethane Clear, activator and maybe a little reducer.
Give the clear time to bite and cure (several days)then sand with a block with 1500 -2000 grit and detail spray ( because it's slick). When perfectly flat, buff with a REAL buffer, not that Porta Cable junk polisher. Use a Maguiars burgandy pad to cut and buff, then a yellow polish pad with non-abrasive polish.
I won't go on until I see the damage but that's the gist of it. I will give you the pad numbers if you want them, and go into more detail if you want to call me. 916-791-7695 tom
Tom
I miss my Tazer
