Old 10-01-2010, 10:49 PM
sideshow sideshow is offline
thanks for promoting us rebel
good to know we r liked
u dont need a square wave into the ford ecu unless u run an auto box
just let it go into limp mode im sure it should no worry it
y doesnt yr elect speedo accept a sine wave
its prob a not popular brand eg not vdo which is what we normally use
most other brands cause too many headaches like this
i have sine to square wave boxes bit cheaper than what u got quoted
but if u then need signal to ford au ecu u might need a signal booster
whenever i wire up ford au v8 with an auto i fit my signal booster from gbox sensor to the engine ecu and this sends the correct signal to ecu so that it changes gears
as for manual gbox i would not bother bout spd to ecu
anyway i do have units to help get yr speedo to work
my website
www.sideshowsperformancewiring.com.au
