Old 10-02-2010, 07:15 AM
Silverback51's Avatar
Silverback51 Silverback51 is offline
Originally Posted by PANAVIA View Post
I wonder if this swaybar upgrade would be overkill for the novice SPF driver -- maybe a good upgrade after you are comfortable in your own skin, and in concert with a good alignment shop.
-- this way you can take advantage of the bar'(s) and not chew a hole in your Avons, or your wallet. -- bars by themselves do not usually alter tire angles, but it is not a bad idea to have the alignment checked out whenever you do a mod.
Personally I don't think it makes a difference if the driver is a novice or an experienced race driver. If the change raises the level of handling of the car, and makes it more predicable, then it's better for either driver.
I will need to buy another set of Avons next year before I go on vacation again. At that time I will have the entire suspension set up checked by a race shop, so I'm not that concerned about the alignment. Although, sway bars should not change the alignment as they do not change the location of any suspension components.
John Hall
