  #21 (permalink)
Old 10-02-2010, 05:47 PM
Rwillia4's Avatar
Rwillia4 Rwillia4 is offline
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
I have a KC engine. Mine also had a by-pass blocked. This was not installed by KC and I would put in the bypass hose ASAP. I was about at the same point of my engine break-in where you are and the rubber cap failed blowing coolant ALL OVER. There is a huge amount of PSI built up on the back side of that thing. It is suppose to allow a controlled amount of flow to so you don't get surges of water blasting by at different temps.
