Old 10-03-2010, 01:33 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by bobcowan View Post
Agree with the above: check the thermostat.
The bypass hose plays an important role. The normal flow of water is through the block from front to back, up to the rear of the heads, and then through the heads from rear to front, and then out the open thermostat. During warm up the thermostat is closed. Water then flows through the bypass hose, and back into the water pump. That keeps water flowing through the engine for an even warm up, and prevents hot spots.
A smart builder would only remove the bypass hose if the thermostat was also removed. But you would really only want to do that on a race only engine. Not a good idea for a street engine.
Very well said Bob, could not agree more.
I teach automotive to apprentices.
I can't count the number of cars I've seen who don't run what they "should be" running.
I walk away in disbelief sometimes.
Gary
