Old 01-13-2002, 02:31 PM
Bill E's Avatar
Bill E Bill E is offline
This shows the pole position upper control arm. This particular one is not what you need. They do make one with the correct cross shaft for your set-up. The lower arms are pieces we fabricate, and are fully adjustable. The HAL coil-overs can be had to fit your set-up. We have used that configuration in several cars with spectacular results. Completely adjustable. Very poised on the road. We will also have a new spindle available with adjustable bump steer and a larger outer bearing, and will accept our new 13" brakes, and wheels with 5 on 5, or 5 on 4 1/2 bolt patterns. Bill E. EMS
Bill Emerson
