Old 10-04-2010, 01:29 PM
SoTxButler's Avatar
SoTxButler SoTxButler is offline
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
Expanding on ACBill's comment:
I use a tape measure from centerline to centerline of the tire on the front and rear of the tire (same height on tire). The front should be 1/4" less than the rear. Then split that for 1/8" tow-in on each side and you'll be good to go.
Russ
