For anyone else fitting a 2 blade wiper set up, the lucas motor i had came with a 90 degree gear. The driver side wheel box would have to be mounted too far to the right hand side that there is not enough room under the dash to mount the motor.
Make sure you get the 130 degree gear to enable mounting the wheel boxes closer to the centre of the dash ( more room there for the motor).
I hope this helps save someone some time.
Damo
