Old 10-05-2010, 11:11 PM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
I ran the car in gear in the air to warm up trans and rear axle fluid to check for leaks and all is OK so far. I have heard others claim light oil like wd40 is OK to use to soak a stuck clutch disc a little to help break it free if its stuck because once you put heat into disc with use, the wd-40 will mostly evaporate and not harm the dual friction material. I am using 500 series Mcleod disc on SS Mcleod flywheel (Ford Racing). Who has tried this or other light weight lube to unstick the disc ? Never been here before, any others been here ? Thoughts appreciated
Thanks
update: i Confirmed my disc is not stuck, it just appears I need more concentric slave movement.
"...some assembly required, ages 8 and up...... well that took longer than expected......
