I ran the car in gear in the air to warm up trans and rear axle fluid to check for leaks and all is OK so far. I have heard others claim light
oil like wd40 is OK to use to soak a stuck clutch disc a little to help break it free if its stuck because once you put heat into disc with use, the wd-40 will mostly evaporate and not harm the dual friction material. I am using 500 series Mcleod disc on SS Mcleod flywheel (Ford Racing). Who has tried this or other light weight lube to unstick the disc ? Never been here before, any others been here ? Thoughts appreciated
Thanks
update: i Confirmed my disc is not stuck, it just appears I need more concentric slave movement.
