Old 10-07-2010, 03:08 PM
RedSnake351's Avatar
RedSnake351 RedSnake351 is offline
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
Originally Posted by azfordman View Post
Understood....but that will have no affect on the stumbling under acceleration. I have been searching for instructions on replacing a manual fuel pump with a electric, but am finding no good info. I figure I will have to install a "T" in the fuel line right before the carb., and run a secondary fuel line back to the fuel tank, but how do I get the fuel back into the tank? I cannot imagine just drilling a hole in the tank and plumbing it in........and removing the tank to have a fitting installed seems like way to much work.....must be a simple in between method.
F-man, forget about it, the return line that is! After the fuel regulator run a pressure gauge and after the fuel log you cap the line. That's how mine is set up.
Ralph
I see Z-link was typing at the same time as I was AND he has a more precise explanation!
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
Last edited by RedSnake351; 10-07-2010 at 03:14 PM.. Reason: Giving Z-link credit for being faster!
