Old 10-09-2010, 12:12 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Cougar View Post
I've always had good luck on any adjustable idle by turning the needle in until the motor begins to falter and noting the position, and then backing it out until it falters and noting that position too. I then turn the needle to be a split beteen the two positions. This may or may not be the exact same as the highest idling setting, but it does seem to run smoothly and seems to give the best coming off idle response.
Yes, you're correct in your procedure, but doesn't apply to the subject of this thread.
Zimmy has stated that there can be differences in the idle mixture screws between Italian and Spanish carbs.
The whole idle circuit could be a different calibration from factory, but the taper of the needle, its diameter and/or the port diameter affect the "correct" idle mixture adjustment point out from seated.
Gary
