Old 10-09-2010, 02:47 PM
Butlers24rth Butlers24rth is offline
Cobra Make, Engine: Butler with Chev 454, decently cammed
Originally Posted by 750hp View Post
Thanks for the information Arthur. I can see the adjustment bolts that you mentioned.
If you're 5'10" and Russ is 5'9" and you're both using the forward pedal position, 6'4" could require some thinking outside the box...!
Craig,
One problem that I have had at 6'-2" is that the gas pedal is the limiting factor as it hits the fire wall. I was going to swith to a cable system as the linkage type does not get the travel I need. I have also put the seat on the fllor with its back against the read of the seating area. This gave me a lot more room.
Scott
