Old 10-11-2010, 07:38 PM
RestoCreations's Avatar
RestoCreations RestoCreations is offline
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Old suspension is out. Im ready to start with a clean slate.
I figured out why the front wheels were on one side and the rear on the other-One rear tire was mounted on a front wheel and one front tire on a rear wheel.
Front
Rear
Can anyone tell me if this is the correct steering sector rod?
And, should this carpet area be exposed after the suspension is installed? The only reason i can think for it to be exposed is for access to the lower control arm stabilizer bolt. Is the carpet simply cut out and the area left open, or does something cover these areas?
All reject and proto-type suspension components are out
