Old 10-12-2010, 10:39 AM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
there is no specific setting. The vacuum generated depends on the engine size, camshaft profile, valve size and choke size. The important thing is to have all 8 throats tha same. Sometimes you may find that one carb gives different vacuum reading on the two throats. I have had to do some throttle shaft twisting to correct that.
Nothing sounds better than a Cobra in a Tunnel !
