Thread: Clutch slave
Old 10-12-2010, 11:48 AM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
If you crawl under your car and look up at the side of your bellhousing, you can't see the clutch fork stickiing out of the hole in the bellhousing and the slave cylinder hooked up to the end of the fork?
Bob in CT's setup appears to be external... I do like the tie wraps If you can't fix it with duct tape or tie wraps it's not worth fixing.
To summarize this and following posts: It is an internal hydraulic slave. I can't see diddly squat, and noone took any pictures when the work was just done, so I have no idea what I have. The only way to tell is going to be to drop the entire trans and housing and open it up. Once I go this far it's the point of no return - the car is off power, so has to be pushed around by hand and stored inside the shop for a week while I hunt down parts. My mechanic is one of my best friends and I don't want to tie up his shop with dead weight - that's an income producing spot to him. It does happen to him too, so it's not impossible, but with the weather turning to winter here, it's harder to work in.
Changing over to something new will just extend the process. I'm not inclined to spend the time or money to get a new bell housing and external setup. A hydraulic TOB without a separate slave is in the solution space provided it will fit mechanically. Otherwise we'll replace the slave and make sure it stays within mechanical limits.
P.S. Thanks!
Tony
CSX4005LA
