Old 10-12-2010, 10:43 PM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Good luck with getting it resolved.
I've recently installed a HTOB (Hydraulic Throw-Out Slave/bearing) on my TKO 600. And I made sure I "measured twice and cut once" to get everything setup correctly. I was not pleased with the conical shimming washers that came with the HTOB. So after taking all the measurements I machined a solid metal spacer and tossed the washers.
I also made sure that the bleed line pointed up so that all air would collect at the top and evacuate when bled. I drilled a hole in the top of the bellhousing for the bleed line and welded a steel shroud to hold the bleed line firm and vertical. Bleed valve in the top of the hose made bleeding a one man operation with 100% success.
Have fun,
Arthur
