Thread: Bonding Doors
Old 10-13-2010, 01:31 PM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
Something else I thought of a little while ago. If you get some small counter sunk screws and screw the panel to the frame ( of course with your choice of panel bonder in between). Then when it is bonded and dry you grind the screw head down just below the surface of the panel and cover them up with some filler. They are there forever and will really bond the 2 parts together pretty much for life
" If it wont break em loose in 3rd gear, it aint enough power "
