Old 10-17-2010, 10:44 AM
tkb289 tkb289 is offline
Originally Posted by LightNFast View Post
Hello Hyde,
I’m actually getting closer to doing just that. I did get a quote from ERA awhile back for a turn-key minus but at this point, I’m still hoping to find something ready to go… plus avoid the wait and of course, save a little money as well.
Thanks,
Kurt
Originally Posted by *13* View Post
The wait can be painful. In the end it is worth it, though. I saw a couple ERA cars as I was researching but there was always something I wanted different. Some of the upgrades or changes can be expensive & knowing everything is new is always good for "piece of mind". If I had found the perfect car, it would have been one thing. But I am glad now that I didn't go the used route. I have everything the way I want it.
Kurt,
I was in a similar situation as you guys ... looking for an ERA FIA and not having a lot of success. So in May of '09 I pulled the trigger and started the process with Peter and crew at ERA.
I wanted their 'street' car, no hood scoop, no oil cooler scoop, solid color (no stripes) and with a grille. They also did a few tweaks to make a bit more room for me to fit, made a custom roll bar set up and the list goes on from there. ERA is great to work with, and a lot of CC members both locally and on line have helped me along the way.
The wait is painful, but knew that going in and hopefully pretty soon, the car will be done
So ... keep looking, they are out there and if it's close enough to what you are looking for, go for it. On the other hand, if you sit down and figure out exactly they way you would have a car built, seriously think about putting your name on the list ... either way you will wind up with a great car
Best of luck !
