Thread: Tig Welder
Old 10-17-2010, 10:55 AM
Rick Parker's Avatar
Default Tig Welder
I have an older Airco 150 DC Heliwelder that I purchased several years ago and used alot when I was redoing my car about 5 years ago. Last night my son called and asked if he could come over to use it to weld some exhaust tubing onto a cat convertor for a friend. When I arrived home shortly thereafter he and his friend were in the garage with the project on the work bench partially welded and obviously having some difficulty. I tried to assist but something was just not right, the shielding gas was not doing what it was supposed to be doing. The weld looked horrible and I just couldn't lay down a good bead. After a little investigation I realized Argon Hose to the torch was leaking at the fitting at the Welder and ultimately that the Argon hose going to the torch (3/16") had degraded to the point it was cracked inside the mesh cove over its entire length, no way to save it.
Those of you that are in the trade or have knowlege, can this hose be bought alone or it it marketed as an assembly with the torch and cord inside a sheath.? I realize Airco is gone but isn't the hose itself universal?
Thanks
Rick
