Thread: Tko/3550 ??
Old 10-17-2010, 11:40 AM
blykins blykins is offline
The older 3550/TKOII's are not related to the new TKO 500/600's. In 1995, the 500/600 weren't available, so most likely it's a 3550.
If you could find one of the TKO II's, they were rated for 425 lb-ft of torque. Here's the thing about torque ratings. The TKO's are rated in continuous loads of torque. So if they'll take 425 or 500 or 600 lb-ft, they'll take it all the time. That means that they're pretty stout trannies.
A Cobra is a very light car and if you run street tires, the tires will break loose before it hooks up and breaks parts. For a street car, you can get away with a little less transmission.
TCRIST,
The older TKO2 trannies were available with a 26 spline input shaft....they are in no relation to the newer boxes.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
