Old 10-19-2010, 02:15 PM
RodKnock's Avatar
RodKnock RodKnock is offline
My clutch master cylinder is mounted adjacent to the transmission bellhousing. The white plastic inlet is where the tube from the remote reservoir brings the fluid. My clutch fork has been scraping against it each time I push the clutch in, and letting the clutch back out. It has rubbed off a good bit of the plastic. If it rubs off enough, it will spring a leak and I'll be SOL out in bumf*** once again.
Ah, now I see it. Why isn't your clutch master cylinder mounted on the side of the engine compartment up high and out of the way?
