Old 10-20-2010, 11:49 AM
madmaxx madmaxx is offline
As far as your oil filter adapter fitting YOU HAVE TO GET THE AN wrench and yes you will be able to tighten. Anything else and you will not be able to get to it. They sell for about $12 at summit, i believe it is 12 an but may be 10an, my wrench is blue if that helps.
Originally Posted by Voyager View Post
This weekend’s project is to swap out the oem motormounts for the Olthoff mounts (pipes are centered, but still occassionally hitting the body).
While the mounts are off, going to try to find & tightned the minor oil leak by the remote oil filter adapter/fittings on the block. Hopefully I can get a wrench on them when I pull the engine mount. Not much space.
Reached 1000 miles on the odometer this past weekend. Loving it.
