Got it back together , test / break in clutch , temper the ring and pinion , lube the Lsd tomorrow ! looking forward to the new gear ratio , and clutch . I changed the brake and clutch fluid. adjusted all mounts , greased everything , checked everything . I changed the trailing arm length and made them the same from back frame , never thought to check it like that before . It may have contributed to some hop .
