Old 10-25-2010, 09:18 PM
tkb289 tkb289 is offline
Originally Posted by cdnus View Post
Did you grease up the bleeder screw threads?
When using a vacuum bleeder you will usually suck air @ the threads making it appear you have air in the system.
Craig
This is a good tip and an important place to look ... air at the threads ... but be sure to use the correct pipe dope or other substance that is compatible with the clutch system components and fluid.
