Old 10-26-2010, 04:17 AM
patrickt patrickt is offline
Originally Posted by tkb289 View Post
This is a good tip and an important place to look ... air at the threads ... but be sure to use the correct pipe dope or other substance that is compatible with the clutch system components and fluid.
We used to call it "Rubber Grease." It would come in teeny weeny little containers, and I vaguely remember them being red. You never see it in the auto parts store anymore -- ever. You'll probably have to pick it up off the internet and you would generally use it when rebuilding a master cylinder (clutch or brake).
EDIT -- Here you go, this is what I'm remembering. LUCAS Red Rubber Grease.
Last edited by patrickt; 10-26-2010 at 04:36 AM.. Reason: Found LUCAS Red Rubber Grease
