Old 10-26-2010, 07:38 PM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
Originally Posted by madmaxx View Post
As far as the Rpush filter they leave out the necessary detail, I qoute
"The new ROUSH Oil Filters hold twice the capacity of the leading brand, and offer a high-efficiency 99.2 percent contaminants capture rate thanks to the superior cellulose and synthetic blend material used in the filter material."
99.2 percent of what Micron rating????????????????? I assume 1000 micron when not told, LOL!!!
Once again burst pressure is meaningless, 5 times, who gives a sheet, nothing in the engine is capable of producing 1 times.
If it is any larger than the 1A it would not fit on my car. I have never seen and auto filter larger than the 1A.
No spec on the bypass valve.
I must stop now before I twist off.
The Roush filter is the exact same dimensions as the FL1, so no problem there. It was free, so I decided to use it. I've got another spare HP, so I won't need to worry about another filter for a while.
Doug
