Old 10-27-2010, 03:22 PM
madmaxx madmaxx is offline
You aint kidding I should drink!!! Wow, Royal Purple sent some serious data, I guess they arent smoke and mirrors, RP accept my apologies. I not going to post the charts since they say confidential.
The pressure drop across the Royal Purple 30-8A, the substitute for the FL-1A is less than 2 psid up to 9 gpm!!!!!!!! Even the name brand RP compared to is only 3.2 psid at 9gpm. Viscosity was 20Cst. 10W30 at 100C has a viscosity of 10.9 cst. A melling rep told me their high volume oil pump is good to 8 gpm, so we are not even close to 9gpm. Even at 20 gpm it differential pressure is 4 psid!!!!!!!!! The RP filter efficiency was 98.5% efficient @ 20μ, the graph supplied was impressive.
The Royal Purple filter is as good as it gets. I did not get their bypass setting but it appears to be cleanside bypass. Even if it is set at 9 psig, the filter is well below that at 2 psid. They are working on the answer and will respond.
RP are available at Pep Boys. They run about $14.99.
The proof will be in the pudding, I will also test the Royal Purple with my set up.
Originally Posted by Got the Bug View Post
OK....I was going to suggest that madmaxx take up drinking again, but now I'm recommending it for all of you.
