Old 10-27-2010, 09:32 PM
YerDugliness's Avatar
YerDugliness YerDugliness is offline
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
Originally Posted by PLDRIVE View Post
Bypass= U guys will never have a issue with this. U change your oil and filter often so the filter is not that dirty. If it were to bypass (very cold) most of the trash is already held in the filter element.
Thank you, I approached this issue earlier in the thread. It seems to me that the bypass function is probably a "fail-safe" to ensure oil flow to the engine in the case that the filter becomes clogged up to the degree that it would not allow adequate oil flow. I change mine probably twice a year, and I doubt that I ever get more than 1,000, maybe 1,500 miles on the oil/filter. I was a bit worried about excess oil pressure, but it doesn't seem that issue is a big one, either.
The issue of "micron" capture seems more important to me....and I have to wonder if there is a greater pressure drop across one of the two filters of the same manufacturer (perhaps MotorCraft) with filter media of different "micron" ratings. (hint, hint, Madmaxx!!)
Cheers from Dugly
YD,E./PNB
No names were changed to protect the innocent!
