Old 01-14-2002, 05:48 PM
olaf herrick olaf herrick is offline
Default Tilton brake question
Hello, I just converted my 9" rear to disk brakes and found out to my amazement that the wheels hit on the calipers. I know I can shave them to fix that problem but while bleeding my brakes(pumping pedal) I noticed the master brake cylinder for the rear brakes is leaking at the base. I havent taken it apart yet but I wonder if any of you have had this problem? I tightened the hose clamp which appears to hold the plastic cylinder to the base and I tightened the hose clamp that feeds the brake fluid. Any ideas ? Thanks Olaf
