Thread: Clutch slave
  #24 (permalink)
Old 10-29-2010, 08:45 PM
Rick Parker's Avatar
Other than the bracket being made of aluminum (OEM was Steel) this is how 289's were done on the original cars. Same setup as on a Tiger too, works flawlessly. I am using a Long style pressure plate (Several coil springs in lieu of diaphram spring) and T10 4 speed. I believe 427's used the same slave but with a different bracket.
[IMG][/IMG]
[IMG][/IMG]
Tony you probably have a McLeod HTOB, the early ones had a real problem, later design were reportedly improved.
http://www.mcleodracing.com/images_products/5192.jpg
Rick
