  #34 (permalink)
Old 10-31-2010, 01:34 AM
Rwillia4's Avatar
Rwillia4 Rwillia4 is offline
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
I had a intake go bad on my SB. It also was a double stack gasket. Talked to Keith Craft and they said it lines up the ports for better flow. They use 3M window sealer between the two gasket, let them tack up then stick them together, put a book on them for weight. Same for the on to the head install let it tack up on both sides then stick them together, "go to lunch" then install the intake. It was easy to do and has worked well.
