Old 11-02-2010, 05:19 PM
blykins blykins is offline
Neutral
Should be pretty straightforward. Keep in mind there are several flavors of Richmond boxes so make sure you match the bellhousing to the input shaft length.
Unless you're hitting over 600-650hp and need a twin disc, I'd go with a less expensive RAM clutch that will accomplish the same thing. I'd aim for a billet steel flywheel with an 11" Long clutch.
Are you buying everything through your builder? If not, I can offer a Club Cobra discount and I'll pick all your parts for you so you don't have to sweat it.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
