Originally Posted by blykins
If you sit with the clutch pushed in and give the transmission time enough to stop turning, it still grinds?
Try this....
When you're sitting there with the engine running and you want to go into reverse, go into 5th gear first, then down into reverse and see what happens.
First thing we tried. Doesn't matter how long you wait or how many gears you engage first before finding reverse. Sometimes it will grind like there is no slowing down of rotation, sometimes it slips smoothly into reverse gear. No rhyme or reason, but heat seems to help the situation.
