Old 11-04-2010, 02:53 PM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
Like Brent said...if the motor is running the pump is pumping. When you tow with an automatic tranny the drive shaft is spinning but you have no fluid because the pump is not pumping. Eventually the planetary runs dry and...BOOM.
" If it wont break em loose in 3rd gear, it aint enough power "
