Old 11-05-2010, 05:39 AM
ogravty ogravty is offline
Cobra Make, Engine: No idea yet. Help!!!
Thanks Rick, i will take pictures of my steering wheel column from the engine side and cockpit. As you said, mine is also 4" x 4" tube base and it seems very strong. No cracks at all in the Fiberglass. The fiberglass on top of the doors are not rolled, just straight in to the cockpit and not parallel to the floor but kind of angles down a little bit as it goes into the inside of the car, but i do not know if that is normal in the cobras. I will also take pictures of the front and rear wheel well for you to see. I'm getting the doors straighten and re-glassed to fix any gaps. Is this company even around anymore? From the pictures of the brouchure, all 4 hinges looks very similar to mine, but i will take pictures of it tomorrow also. If in fact my car was made using this kit, are there parts avaliable for it? i mean like the softtop or tonneau. I want to get one but i'm not sure if the ones from other companies will fit. I know i can't use the factory five tonneau since it doesn't really fit, but i'll try it again tomorrow, the shell valley tonneau was closer to it, but as i said i'll try again after work or just have one custom made. A soft top would be nice though. Thanks once again Rick.
