  #24 (permalink)
Old 11-07-2010, 05:22 AM
blykins blykins is offline
Do you have a dyno sheet or at least a build sheet?
If it's making that much power, you need to have the TKO modified (if you want to keep it) to 1. hold more power and 2. shift better at higher rpms.
You'll also need more clutch. If you're running any single disc clutch (unless it's something like a McLeod Soft-Lok or an equivilent drag race only clutch), it will start slipping with 700hp. You can bet on it.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
