Old 11-09-2010, 02:16 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
Originally Posted by Z-linkCobra View Post
Gas fired furnace should not run the compressor or outside unit when in the heat mode. You have a wiring problem with you t-stat. I would have to look at a wiring diagram to know for sure. But if i remember correctly there is a jumper wire that has to be removed for electric or gas heat as oppsed to heat pump.
The only time your outside unit should run when in the heat mode is if you have a heat pump.
Have someone check it out for you, at this point your electric bill is going to go through the roof. Your trying to chill and heat the air at the same time.
Yeah, I didn't think that they should run together. Burning gas and spinning the meter at the same time is not good........anyone know how a neophyte like me can troubleshoot this thing? No budget right now to call a guy in......
