Old 11-09-2010, 03:32 PM
Well done Z-Link, you covered that nicely. Another possible easy solution may be to simply turn off the breaker for the AC unit(s). There should be one fairly close the unit itself, typically mounted outside the house.
It does sound like a T-Stat wiring problem and it is likely at some point you will have to call in a professional. I'm retired, so that leaves me out!
