Thread: rmc suspension
Old 11-09-2010, 06:28 PM
Rebel1 Rebel1 is offline
Originally Posted by David Hodgson View Post
Hi welcome Elvis, Can't help much with the loose spring issue except to say RMC's series I & II had bump steer issues which is relatively easily addressed. There are a few threads regarding this if you have a search. I think by lowering the steering rack.
Indeed David is correct with regard bump steer. Lowering the steering rack is the easiest solution.
However, of more important concern is the failing of the front upper A-Arm mounting plate. This plate to which the Jag pivot bar is bolted flexes and will break causing that side suspension to fail in a big way.
RMC did provide a fix but many many RMC owners were not advised of the issue nor received the modification.
