Thread: DRB 540 build
Old 11-10-2010, 01:34 AM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
Boxhead
From about car 30 the have changed the firewall so that the entire heater aircon unit fits in...it doesn't in previous models you have to use their modification Kit which runs into a couple grand... now they have shifted the centre part of the firewall forward roughly 75mm and dropped the height of the tunnel...to let it fit. The tolerances must be tight from the tunnel to the box...Nothing an angle grinder and a Tig can't fix
