Old 11-13-2010, 12:55 PM
madmaxx madmaxx is offline
Why is seat pressure important? It would seam that the open pressure would cause the valve train wear. I am pretty confident if he went with either of the next two larger cams he would float the valves unless he increased valve spring pressures or kept it below 5500 rpm's. I dont think he could ever get 600 hp, heads say max valve open is 600 where the one cam is above that.
