Old 11-13-2010, 03:18 PM
That happened to one of my two carbs recently, steadily got worse to the point where I had to "blip" the throttle briskly to get the idle to return to normal. Tried a heavier spring, re-routed the spring(s), nothing helped. Finally took off the carb and inspected on the bench. The throttle plate action is just a hair sticky, it won't return to full closed position without a slight push. The return spring was side loading it in such a way as to exasperate the condition. I keep an identical spare carb so I replaced the sticky one with my spare one. Idle is once again perfect. Which now leaves me with a defective spare carb.
I'm not sure what's going on with the throttle plates on the bad one. I tried WD-40, carb cleaner, etc, it still hangs up just a fraction. That carb is only a couple of months old, no carbon or nasty stuff on it. I suspect it's just flat out defective out of the box. Bummer....
