Old 11-13-2010, 03:30 PM
RET_COP's Avatar
RET_COP RET_COP is offline
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
If your springs are pulling the throttle blades closed in the same direction you throttle is pulling the throttle blades open there is a lot of side load on the shaft which can cause misalignment and binding. [your throttle open action being on top and the spring closing action being on the bottom]
Try putting the springs on the opposite side of the throttle action [pulling from different directions] which will balance out the load and maybe stop some misalignment and binding.
Lou
Lou
