Old 11-14-2010, 05:05 PM
dcdoug's Avatar
dcdoug dcdoug is offline
There's always the wild card issue of oil-filled coils being mounted sideways, so you get an increased mark on a response if you include it. I bet you just clogged up the bleeds a little bit with that goofy two-step you did with your fuel pumps last week. A blast of carb cleaner down all of the bleeds will probably make it go away.
The coil is mounted vertically. Bleeds blasted with carb cleaner.
Hopefully, I'm good. I'll report back if I'm not.....
www.partskeeper.com
