Old 11-15-2010, 08:48 PM
tcrist tcrist is offline
Originally Posted by Jerry Clayton View Post
Terry
tell us about the thickness of your lower mount for your rear coil over
Lower coil over mount is 3/16 thick steel stamped plate with rolled edges for strength (stock 8.8 bracket) and another 3/16 thick plate welded to the inside.
Upper coil over mount is also 3/16 thick steel formed (stock CR frame) with welded in 3/16 steel gussets and plate for strength.
Motor mount bracket that bolts between the frame and the engine mount is stock CRII 3/16" or 1/4" steel plate fully welded and with 3/16 steel gussets welded in for strength.
Any other information you need Jerry?
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
