Old 11-16-2010, 12:25 PM
madmaxx madmaxx is offline
I do not have a picture but the "upgraded" spf mounts are second to none. 4 bolts hold the motor mount to the frame, three bolts hold the other half to the engine and massive bolt acts as the pivot. The spf crappy rubber mounts dont break but flex to much allowing the side pipe to hit the opening. The upgraded absorb moutns are wonderfull, as close to solid as you can get but the advantages of a flexible mount.
I would bet 1000 ft-lbs of torque could not deform the mounts.
