Originally Posted by blykins
It would be a lot of work.
Pistons have to be changed, heads have to be modified, and the block deck has to be modified. Plus you have to try to find an intake that will work with 2V heads and a 9.500" deck height block.
The Cleveland heads make good power for stock parts. Maybe you could use the Cleveland engine instead of the Windsor....
I thought about using the C motor but it just doesn't have "style" It has the look that says "I'm and anchor". Besides , I know the small blocks and the FE's much better.
