Old 11-19-2010, 07:46 AM
azfordman's Avatar
azfordman azfordman is offline
Cobra Make, Engine: CCX-3-3624, 351w, 5-speed
Originally Posted by mr0077 View Post
AZ, what you just described ("The vacuum reading rises steadily as the RPMs increase. When shifting, between gears (clutch in and throttle off) the vacuum will jump up to 35" Hg then drops down to the 10" Hg as the next gear is engaged and throttle is applied again.") is not possible; an absolute vacuum is 29.92" Hg, so you can't read 35" Hg. If the gauge is reading high by 10" Hg, you would get the readings you recorded. When you get around to working on the vacuum side of things, I would get a second gauge to check your readings.
My bad....that's what I get for taking notes at night while trying to drive the car!!! The gauge only goes to 30....so I should have said 25.
"Freedom is only an illusion when the government has all the guns."
